Seat bolt cover
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1791081245#check"></use></svg></i> Discussion starter Discussion starter Joflo
Joflo
South Texas
R18 Roctane
Are there any smaller seat bolt covers? I installed the tc top case carrier but the cover for the seat bolt on the roctane was in the way and needed to he removed. I was able to make it work without the cover but want something to put in its place.
If you mean the end piece, I think you can find that part from the single seat cover. I attached the diagram for the part. I’m not sure if this is exactly what you’re looking for, but I hope it helps.
