PhilBret
Hello,25mm shorter and rides great!
I have some spacers for the rear Shock in the Kit . Did you use them on the hyper pro ? They are the same Shock absorbers .
Hi David - is this the Same one from Touratech that PhilBret has installed ? Thanks for the feedbackNew shock finally showed up. I paid for it Aug 11. It came November 18.
Installation was easy. They sent me the wrong shock, it was supposed to fit with my original preload adjuster. For now I just set the sag to 12 mm with out me on the bike. It RIDES MUCH BETTER!
I took the wife to Letchworth state park. About a 200 mile ride for the day. No more sore back. It no longer throws me off the seat. Its MUCH better. The bike rocks a little when I hit the brakes or squats when I hit the throttle. I can bounce it a little at stop lights alone or with passenger.
The small bumps disappear, the big bumps are now small.
Still adjusting, now I am at
25 for Rebound
20 for low speed compression
25 for high speed compression
Recommended is
20 rebound
15 high speed compression
15 low speed compression
Still fine tuning, but what a difference.
Too bad BMW didn't include such a nice shock.
David
go to the touratech web site. select your bike , you ll them . They are called black T but are Hyperpro made.
Hello, I am wonder if there was any lowering with the HyperproHello, I purchased a hyperpro rear from emp performance very pleased with it.....
