Rear conversion
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1791081245#check"></use></svg></i> Discussion starter Discussion starter R18Holan
R18Holan
R18FE
We got rid of a lot of plastic by replacing it with a delicate stainless steel structure (painted black) and we moved the indicators to the rear of the fender and replaced them with a more classic design.
Neat job!
Do the turn lights work the same than the OEM?
I mean turn/red/brake, in addition to the central brake light?
I haven't connected it yet, but it should be like that, because it's dedicated 3-in-1 turn signals from Kellermann
Bullet 1000® DF - Indicator, rear- & brake light "3 in 1" combination
"The Bullet 1000® DF is a rear indicator in combination with a rear and break light function. It replaces the existing indicators, break and rear light. The light of the continuously glowing red rings give the tail of the motorcycle a spectacular look**. When breaking, the light circle of the break light shines strong and clear, the clear message to the following traffic is: Keep your distance."
