Kanzig
The mirrors that came with my R18C were set completely wrong to see anything behind me. In the process of trying to tilt and adjust the angle I realized these mirrors are rigid and it appears you cant pivot them like most, is that correct? Felt like I was going to break the mirror if I forced it to angle inwards. It seems (to me) for horizontal adjustments you need to swivel the mirror at the base of the stalk by loosening the nut below and then re-tightening. Vertical adjustments are done by loosening the clamshell that holds the clutch assembly or brake assembly, rotating it on the bars slightly and then re-tightening. Is this correct? Ive never seen mirrors that you cant adjust while riding. Am I doing it wrong?
