R18 OIL FILTER WRENCH
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1791081245#check"></use></svg></i> Discussion starter Discussion starter BAD MIKE USA
Is it true that the space the filter is in is very tight and some filter wrenches won't fit in? My first change on this bike. I have had it done before by a small BMW/MOTOGUZZI shop, not dealer, near here. The reason I don't want to buy the BMW filter wrench is I want to install the K&N filter with the hex head. I assume the BMW wrench is pricey for a single use.
The filter in my pic worked fine for me. It was bought at a BMW dealer in Kansas City but interestingly enough it says "Illium Works" on the other side.
I'll take a pic of the other side. I noticed immediately the Ilium Works lettering. It was odd because I was at Engle motors in KC and assumed they would sell me a BMW labeled oil filter wrench.
I switched to K&N (with the socket tip) because even with a good oil wrench I still had a lot of trouble getting them off--just doesn't grab that well
