R18 Foot Controls - Large Feet Solutions
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1758297946#check"></use></svg></i> Discussion starter Discussion starter CadillacFan
CadillacFan
R18 Classic
Hi Everyone
I'm reaching out to see if anyone else has an issue with the relative ease of access to the gearshift and the rear brake
I have size 46 riding boots and have the feeling that the positions of the above pedals could be more easily accessed while using the stock footpegs on my R18 Classic - they feel like there is not much space to quickly reach them - clearly not ideal. It feels like the rubber peg should be a little longer??
Any feedback or advice / views of footboards / modified pedals etc on this will be most welcome
Thanks
Alan
Hi Everyone
Thanks
Alan
I’m also a 46 boot. My Classic has the floorboards. No problem with either shifter or brake. Very easy to reach them both. The brake is just ahead of the floorboard, so it is very easy to engage. The shifter is the same. You can rotate to adjust to your preference.
Hi Everyone
Thanks
Alan
You can put a little bit higher the factory Gearshift, in order to get in your foot easily
Hi Everyone
Thanks
Alan
I had the same problem, size 12 US feet. I couldn't upshift with my toe. I replaced the floorboards on my Classic with the flat footpegs of the Bagger. It's a direct swap to the floorboard mounts. Cost less than $200, works much better for me and I can toe or heel shift. If you do this, also order the return springs with the pegs. The spring has a different bend than the spring with the floorboards. An added benefit for me is being able to move my feet around a little more.
Great video - thanks
Will try adjusting the hear shifter - but still need a solution for the brake pedal??
I was looking to do the same thing to lower the rear brake lever. It looks like you just remove the spring clip, loosen the jam nut and adjust it from the rear side of the rear brake cylinder.
