R18 B / TC Installation of ROCTANE Rear Case Filler Panel
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1789222567#check"></use></svg></i> Discussion starter Discussion starter Deleted member 1618
It sounded like they missed sending it as part of the kit; I spoke to Russell at Max. I used hardware and rubber buffers that I picked up at the hardware store, while I wait for the correct hardware to arrive.
Thanks. I looked up the part number for the panels on their parts fiche, I can’t get it to come up.
Call them, that's what I did... They were very helpful..
I went down to my local dealer, they looked up the part and said zero in the US, x amount in Germany ( I forgot). Then they said for whatever reason that they couldn’t sell it to me. Guess I will call MAX. :-|
I had to get parts from Germany through MAX .. and it was surprisingly fast ... sub 3 weeks and I am on the other side of the US from MAX.
Hello , I ordered the parts on 26/10 from https://www.pieces-bmw-moto.fr/, using the references I receive them Friday.
Bonjour , j'ai commandé les piéces le 26/10 chez
https://www.pieces-bmw-moto.fr/ ,en utilisant les références. Je les reçois Vendredi.
Désignation -------------------------------------Référence------------Prix Unitaire TTC-- Qté---Prix TTC
BMW - TAMPON EN CAOUTCHOUC-----------07 14 6 841 695---------2,04 €-----------10-----20,40 €
BMW - CACHE BLACK--------------------------77 31 5 A7F 049-------117,00 €------------1----117,00 €
BMW - VIS CYLINDRIQUE M5X16-8.8-ZNNIV-07 12 9 907 412----------1,61 € -----------8------12,88 €
The kit had to be ordered from Germany as well; if you decide to order it from Max BMW, try asking for Russell, he was extremely helpful during the ordering process and is familiar with the kit at this point.
Russell just emailed me yesterday, stating that the missing rubber buffers arrived; I temporarily used automotive rubber buffers to install my panels. I'll replace them on a cold wet weekend day when riding isn't ideal... Should take less than hour, as I really only need to remove the side cases, to get to the screws in order to slide the panels up and out and replace the buffers.
Just received my kit today and the 10x Rubber buffer and 8x M5x16 Torx screws were not included:(
They didn't initially come with the rubber spacers and hardware; however, MAX BMW mailed them to me separately, at no extra charge.
Attached is the receipt from Max BMW located in CT; I purchased the Black Storm painted filler panels for my FE Model B, you might want to purchase the Primed panel and get it painted locally for your bike color:
Maybe try calling Russ at Max BMW parts department?
