R18 B Brake Fluid Flush Instructions?
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1789222567#check"></use></svg></i> Discussion starter Discussion starter LCRC18B
Hello,
Does anyone know the procedure to flush the brakes on our bikes? With no manual, I'm hoping someone with more experience than me knows if it's similar to a GS or another model?
Thanks in advance.
I do a lot of my own maintenance but for brake flushing I take it to the dealer. The modern abs systems can be tricky, to do it well you need tools like a mighty vac or speed bleeders… and brake fluid is caustic. It’s just like bleeding any brake system if you choose to do it but unlike a car the fluid is close to paint and brake fluid will take the paint right off a bike.
I saw that the GS-911 tool allows for the ABS pump to be actuated, in order to service the brake fluid; I typically let the dealership handle the brake fluid service, I agree... the brake fluid is way too close to painted parts...
A Miti-Vac, little bit of plastic sheet and a towel is quite a bit cheaper than what the BMW dealers charge.
