Pinout needed - Instrument Cluster for R18/R18C
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1791081245#check"></use></svg></i> Discussion starter Discussion starter JAMUSAURUS
will do.
I'm backtracking on my previous comment but rethinking that the 'system' information like Date, time, service data, and other accessories are pulled from the Grey/Purple wire as the other instruments don't use this info and is displayed on the headunit on the K35. My theory here is the Grey/Purple is also a CAN/LIN BUS network, but for other data not related to engine data (such as heated grips, signal light, aux commands, neutral switch, etc).
It’s been 84 years since I started this journey but it’s finally done. I have a working factory tachometer and it how it should’ve come from BMW.
I’ll create a new post with part numbers and pictures of this journey.
