Pillion Seat/Footpeg Removal/Delete
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1789222567#check"></use></svg></i> Discussion starter Discussion starter Svtweb
Svtweb
Moderator
Staff member
Elite Member
Westminster, Maryland
2001 R1200C, 2012 K1600GTL, 2021 R18 First Edition
For those that wish to remove the passenger pillion seat and the passenger pegs, it is very easy to do. Using a T-30 Torx, remove the single bolt holding the chrome trim cover at the back of the pillion seat. Gently lift the seat by the back and slide backwards. Then use your T-30 Torx to remove the 3 bolts holding the grab strap. Save the middle bolt for placing the Chrome trim cover over the rear mount of the riders saddle.
Using a T-60 Torx, remove both foot peg assemblies. When you get the bolt loose, hold the peg with your hand and remove the bolt completely. Use compressed air to blow the locktite residue out of the peg pocket to avoid scratching the paint.
Now you have no pillion seat (It is less room than the passenger seats in a Porsche 911) but you have 3 holes.
For the hole in the fender, order part number 46629444675 from your local BMW Motorcycle dealer.
For the footpeg holes, you CAN NOT get the part from a BMW Motorcycle dealer. They have the part number, but BMW Motorcycles and BMW Automotive are two separate entities and don’t play well. BMW Motorcycle stole the part from the automotive parts bin for the 4 Series cars. It is part number 51717056053 “Blind Plug”.
Hopefully this will help some other people.
Did you want to sell the footrest hangers and pegs ?
I used a couple of body plugs for plastic car underbody things like say behind the headlights in the forward wheel wells. My buddy had a couple and they snapped in perfectly, do not bother looking for the BMW 4 series part, it is expensive, as rare as hen's teeth and one does not need it!
