Pedestrian Slicer - Front Fender License Plate Installation
Normally it's intended to show the registration number .
If you haven't yet drilled the fender, shouldn't you locate it a bit more toward the front end ?
And sharpen it ... :devilish::devilish:
And it is probably intended for a larger fender, like that by DKdesign.
I put one on mine too. It has a roundel in the middle, and on the left side it says R18, and on the right side, TC... I attached it with a combination of neodymium magnets and epoxy. Didn't drill holes in my fender. I got some clear paint protection film, cut two round pieces about the size of a quarter, and stuck them onto the fender. Then put some neodymium magnets on the base of the plate, and epoxied them onto the round pieces of clear film for extra stability. If I ever want to take it off, my hope is that the epoxy will be stuck to the film and the film will just peel off the fender clean.
