Original factory windscreen for 2021 Classic First Edition
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1789222567#check"></use></svg></i> Discussion starter Discussion starter aicpjim
aicpjim
2021 R18 Classic First Edition
BMW OEM windscreen. I bought a taller aftermarket screen so I no longer need the stock original. $50 plus shipping to your address.
Sounds good. Let me measure it. I assume it's 16.4 because it was the stock shield from a '21. Once I get the measurement, I'll be back in touch
It appears to be 16.75" tall
16.75 is fine. Is the width 15.9”? The reason for my questions is because I like the proportions of the OEM low windshield which is tapered towards the top. Is this standard for mounting for 2022 R18? I’ll follow up myself for fitment. Thank you for your time sir.
The width varies as it tapers to the top, but it is about 20 and a quarter inches wide for most of it, which is it's widest dimension. I can't answer questions about '22 model year fitments. I just don't know...
The mounting fitment is standard for 2021 and 2022. It appears that what you have is the medium height windshield which is 18.8” H and 19” W. What I am looking for is 16.4”H and 15.9” W. Thank you so much for your time.
