Ok I bought The R18 Transcontinental
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1789222567#check"></use></svg></i> Discussion starter Discussion starter Billt1NH
I have the comfort high seat on order as well as leg rest
Okay, so the stock seat needs to go. I was going to opt for the 719 seat, as it seems to allow you to move back further than the stock seat. I'm 6'1" so maybe the comfort high seat would be the better option.
I wonder if it's possible to order the wheels from the non-719 option TC? I like those better than the stock black wheels that come with the 719 TC, and I don't see them listed as an option on the website.
All of the many bikes I have owned have had center stands. I can understand this bike doesn’t have one being so heavy. But I can see rolling the bike back and forth to put air in the tires and clean the wheels will be a pain. :(
There is no option for a center stand, correct?
Typically ,stock oem replacement parts are more expensive than the aftermarket.Example:The R18 Classic mufflers(maybe the same that are on
the R18B & R18TC)are around $3200 a pair.
Good Luck
Good Luck
During the order/build process of the TC, I was just wondering if it might be possible to switch from the TC’s stock rims to the FE’s stock rims without incurring any additional cost?
yeah,I don't know the answer to that question.
