Welcome to the BMW R18 Forums. Member registration disables ads and allows you to post and share. Register Here.
A few people have been scammed on the site, Only use paypal to pay for items for sale by other members. If they will not use paypal, its likely a scam NEVER SEND E-TRANSFERS OF ANY KIND.
Not the head gasket, that one is way further toward the engine and it wouldn't leak oil ... did you just do a valve adjustment on that bike? ... if yes, take your Black RSD cover off and make sure the 2 actual valve cover screws are tight (Large torx under these silly sheetmetal brackets) ... if they are ... just clean it up and see if it goes away. I had that on mine before, when I put the cover back on, a small amount of oil 'hides' someplace and that drips out the first time the motor gets hot ... if it continues to leak you may have a bad valve cover gasket ... but most likely it is nothing .. I have re-used my gaskets now 4 times and they hold just fine .. but that is just my 2¢
Doh. Yeah, I wrote "head gasket" but was thinking of the valve cover gasket. Darned, new-fangled motor with the valve cover cover through me off. .
This is pretty much what I'm planning to do tomorrow.
No service recently. It's at about 3K miles now and it's been about 6 months since the 600 mile service. I keep a close eye out for drips out of habit since I work on my old airheads. This is new since my last ride a few days ago.
Damn ... If you just did a service, that would have been too easy ... maybe one of the bolts did back off a bit, that would be the easiest and I hope for you that is what it is ...
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
