Noco NLP30 battery upgrade Amazon prime
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1791081245#check"></use></svg></i> Discussion starter Discussion starter Deleted member 2560
Sorry to hear you had a problem. What happened?
If I was to switch to Li; hands down, it would need to be an approved battery from BMW with the BMW charger.
I see too many Li knock-off batteries catching fire here in the City; a battery failure could easily extend from your garage and into your home. I would be sleeping with one eye open...
I’m sorry, what problem have YOU had with the battery?
Interesting how the argument pivoted. At first is was a “Chinese fire hazard”
Once shown BMW is implementing the technology, it became “some Chinese knock off”.
I have asked twice, please tell us what experience(s) you have had with NOCO batteries.
No, the individual that keeps calling them knock offs and fire hazards. I use these batteries, if someone on this forum has personally had an issue, and not read what some yahoo did with a unknown brand lithium battery and an improper charger, I would like to know. As of yet, no one has come forward with a personal negative experience. I completely understand if someone doesn’t want to use one, I was skeptical 10 years ago when I used the first one ( not a NOCO, but a lithium battery). Since then I haven’t looked back. All I am asking as a forum user/contributor is, if you are going to trash something, please be able to substantiate it.
Thank you
Actually the Optimate 4 Quad Program | PREMIUM Edition (CanBus) does not work Lithium-Ion which is what the NLP30 is.
It only works with LiFePO4 lithium batteries,
Other Optimates can do LiFePO4 but don't have CanBus.
So the option would be to get a NOCO charge and a pigtail.
ooops.
Missed that. Thanks, no want no Lithium-Ion. Shido is LiFePO4.
When the time comes I'll replace with the OEM 61218414924 or the Yuasa YIX30L
That way I keep my Optimate 4 CanBus which has served me so well thru my last 4 BMW rides.
