Next level big boxer culture
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1789222567#check"></use></svg></i> Discussion starter Discussion starter fleabag
Does the B rear fender bolt straight on?
No. The modification was not as easy as I had thought.
I actually replaced the fender and rear frame so I could find the original mounting points of the B. Then I drilled the mounting points to bolt the 2 Classic saddlebags on.
When I first laid eyes on that red B model, a surge of desire shot up my spine. Anyway, I am very glad the R18 line-up is alive.
Same here. They've done some great upgrades that I've already done to mine. The only thing I would like to have is the bigger front fender, and also larger rear fender, and I will probably end up doing aftermarket. Glad the r18 is still going. I may add a transcontinental to the arsenal this year👍
