My work in progress over my R18Bagger
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1791081245#check"></use></svg></i> Discussion starter Discussion starter Tigeos
Wow that was simple and fast; no that is a thing of the previous century and long since out of production.
There are however modern, higher tech solutions in rvs!!
Here a supplier located on the British islands:
[/URL][/URL]
Now I understand what you are saying and I have them in my wish list on Amazon is only one thing, there heads are chrome! How ever will I see in the end to use this ones,I will see.
Now I understand what you are saying and I have them in my wish list on Amazon is only one thing, there heads are chrome! How ever I see in the end to use this ones,I will see.
OI am very sorry but English is only my third language and you have lost me. Never mind, I understand that you will decide.
Hi good evening good fellows, two days ago I take my Bagger to this great boy here in Scotland to do my pin strips and after a day I take it back. This are the results and I am so happy with !
Hi good fellows some accessories and a few coming, but next week maybe because need to take it for services ( informative which is going to cost about 400 GBP in Scotland for oil, oil filter and brake fluid ) so
Mirrors
Long Stem Mirrors Fit For BMW R 18
Knee wind protection I bought the small one first and the bigger one after, so I am going to put in here photos of both and size to size just for comparison
Small ones
Wind Deflector Side knee
Bigger ones ( me I painted on gloss black paint what ever it was silver, chrome )
Knee Protectors Windproof
Comparison between them size by size
... so today I install this ones, a Mobile Phone Holder Support which need a little work with the metallic ears to get o the holes, my personal intention is with this one to use it for cameras front and rear screen but is not decided, I am still looking !
Rod Headstock for BMW R18B R18 Transcontinental Mobile Phone Holder Support
... second, a metallic cover for the oil radiator,
Protective cover for oil radiator
enlarger foothold ( this Chinese are crazy to send chrome screws on black accessories and they are shorter ! ) with M5 25mm black screws from Amazon
Enlarger Plate Kickstand Extension Pad
... after 8 days using this foot hold I realize, is not worth ed! You are hitting your back of your leg all the time!
May a lot you my dear fellows you know about this, but I am adding and this one in here because I see a lot of comments about electrical connections in which some peoples saying about a electrical device ( auxiliary lights, horns, GPS ) was draining there battery! Well good fellows the ACC cable is to be connected to a fuse which is closing when you kill the switch! Now what I want to say with this small fuse box which I found on Ebay UK ( all of you using your internet search, I am sure you are going to find it ) you can add other 4 electrical accessories and is having a relay ( which you still need to find and connect to a ACC source on your bike ) but you'l not need to connected all the others, how ever the cable which is coming from the device for the ACC, you are going to connected with the + cable from device on the same spot for the box +!
4 Way Fuse &Relay Box Quick Wiring 12V 20A W LED Indicator Light For Motorcycle.webp
My next project is to make this one to work
12V Klaxon Ahoooogah Old Style Vintage Air Horn Chrome Klaxon Car Truck Trumpet.webp
to work throw this one ( look for a large one for our handlebars )
Motorcycle 78 Handlebar ATV Headlight Fog Spot Light ON OFF Switch Waterproof.webp
Motorcycle Handlebar ATV Headlight Fog Spot Light ON OFF Switch Waterproof
from the same original BMW original horn switch. I have a problem to cover the wires on the back of the horn ( because the Chines are not using any cover for this one ) ! If any one have any idea how to make waterproof that back side, I am open for suggestions, please!
26/04/2026 Update, unfortunate on this one, I was not been able to make them work and the reason behind this I think it is the switch, is something wrong with the switch ( the wiring plan which we see in the photo is not working unfortunate ), so I will do it working by himself! I do not drop the idea, I will still looking in the future!
I try to make it work from the same OEM horn push button, but unfortunate I was not been able to find a proper waterproof switch to change between them ( I do not want them to work together ) so I did it to work throw his own switch!Installation of a Horn with Vintage Sound on BMW R18 B
I was just been informed throw email by Robert Becker Design, now they have the seat lock available for BMW R18 and and with the possibility of choosing of how long you need it, 15 and 20 mm long! I am adding the web link here also I suggest for any concerns before purchases to get in touch with Customer Service! They are very helpfull!
Today I install the Aoocci Motorcycle BSD Radar – Blind Spot Detection & Lane Change Assist
Is working but with out any install instructions on the box you are going to make mistakes having the radar upside down so left to right and right to left! Have in mind the signals are marked with L and R, but the radar is having just an arrow, so you need to guess ( any one have a contact for Harry Potter to help me ) which direction that arrow is going to be! Also I will prefer between the radar and all the others to have one more connection, to be more flexible on installation! So you need to understand, after my first test when I was having the cable under ( the light signal I have them like the marker is saying L and R ), but when cars was over passing me on the Right the Left signal it was lighting, so this is the reason which you are seeing the cable on the top ( arrow up ) because I do not want to install all the cables again. Simple if you want to have the cable under, then from beginning you need to change the signal between Right to Left and Left to Right!!
Now about price, me I paid about £64.27 Aoocci Motorcycle BSD Radar – Blind Spot Detection & Lane Change Assist, but after I found on Aliexpress Unmarked but to me is looking the same £38.19 ABQD!Motorcycle Radar Detection Radar Detection System Blind Spot Radar Detection System Millimeter Wave Sensor Merging Assistan and a second one £46.48 Motorcycle Safety Kit 24GHz BSD Radar Blind Spot Monitor & Lane Change Alarm IP67 Waterproof Moto Warning System accesorios moto, so you have the possibility to chose! Me I all ready buy it when I soo this ones and because this are not Aoocci ( which are still made in mother China ), you are not going to lose, have in mind no instalation description in the box, also the Aoocci device is not marked nowhere with the company name !!
Robert Becker Design, metric seat lock'sView attachment 21219
Does it or can it double as a helmet lock??
I used a helmet lock, which was originally designed to replace the clutch reservoir bolt on the handlebars in the past; I really didn't like the way it looked at the tail end of the Model B seat.
I'm not sure if I posted any pictures in the past...
