Hi Terry,Hi David
I have an R18 Classic and I am 6ft 3 I have put the Weekender seat with the View attachment 11381driver's backrest on and footboards with the Wunderlich's leg rests and front Motea crash bar. This combination is great for me. I have just come back from Wales and have been riding 200 miles per day for 8 days with no issues. hope this helps.
Thanks for sharing your shifter modifications on the Bagger!On my Bagger, the shifter pegs were too short and i did not like the heel shifter. So i used the rear or heel shifter arm as others have done for the front but added the black adjustable extension that was on the original front part of the shifter to it. I also added the longer peg to the arm. Now i dont have to bring my foot so far back to shift and i can still get my size 11 under the peg. No issues with downshifting either. And it is still adjustable at the extension..!!! I found an aluminum spacer to put in where the original rear arm was located.
Awesome to hear from another tall rider! Your tall comfort seat setup on the R18B sounds like a game-changer, especially with the backrest for those long rides. Nailing 350+ mile days comfortably? That's seriously impressive.6'6" here. R18B. Tall comfort seat was the only change I made. If I know its going to be a long highway day I'll pop the backrest on. Feels like a comfy recline with my feet up on the highway rests. I've done several 350+ miles days with this setup.
Thanks for sharing your setup with the 719 seat and the "wild ass" addition on your bagger. Sounds like a neat solution for gaining extra height and space, something we definitely need at 6'3".I have the bagger with the 719 seat and I added the “wild ass” seat to it and it allows me to sit higher and further away (I’m 6’3”). It sits you up higher into the wind, buffeting is worse ect…it’s like playing “whack a mole”
I'm only 5'11".... but really struggled (FE Pure).... I thought of it in 3 ways.... 1. bum comfort, 2. knee and hip angle and 3. Bar reach'n height. In my case I am only looking for 2hr bum comfort.... but hip/knee discomfort was almost instant on this bike for me.... so my priority was 2 then 3 and lastly 1.
I needed to come up (2" so far for seat).... with bars back 1". Siting a bit more upright helps with hips.... but bars back 2" felt a bit better... but once over 60mph it wasn't..... so went back to 1" for the bars. (I bought 1" and 2" cheap extenders to try for a week or two).
I went with a homage seat to play with riding position since it is easy to fabricate mounts to play with positioning....most other seats seem to be a buy and see how it goes propersition..... with all the padding in some it is impossible to antucipate hip/knee positioning etc.
The homage is not a bum "comfort seat"..... 10mm gel under a lambswool seat cover helps.... along with soft mounts for the seat itself.... for 1/2 inch or so spring.... bum comfort is then good for a "pure"... not plush.... a 2hr seat.
If using floor boards.... foot angle.... especially lifting the heel without lifting the whole leg was also uncomfortable... the height of the heel shifter because of the seam on the fishtale exhaust was an issue. I swapped the toe and heel shifter over and added extension... this allowed the heel shifter to come down more and not fowl the exhaust.
I added a taller after market windshield, which helps a lot. I have the engine guards and leg rests- which work great. I did notice that a lot of buffeting comes from over the engines/gas tank. I am thinking the lower deflectors would help on longer trips- which I’m planning on taking this June- going to Grand Canyon and up the million dollar highway to Vail, then back across to NJ.Thanks for sharing your setup with the 719 seat and the "wild ass" addition on your bagger. Sounds like a neat solution for gaining extra height and space, something we definitely need at 6'3".
I get what you mean about it being a bit like "whack a mole" with the trade-off of sitting higher in the wind and dealing with more buffeting. Always something to tweak, right?
Have you tried any other mods to counter the wind issue, or found any tricks that help balance comfort and handling?
Did you buy a windshield extension or is it a customized taller windshield? I’ve been thinking about buying the extension but I’m not sure if it has a negative impact regarding visibility. Any thoughts?I added a taller after market windshield, which helps a lot. I have the engine guards and leg rests- which work great. I did notice that a lot of buffeting comes from over the engines/gas tank. I am thinking the lower deflectors would help on longer trips- which I’m planning on taking this June- going to Grand Canyon and up the million dollar highway to Vail, then back across to NJ.
I’m looking at bringing the handlebars on my Classic back 1-2 inches. Did you have any issues with your brake and clutch lines, or wiring?I'm only 5'11".... but really struggled (FE Pure).... I thought of it in 3 ways.... 1. bum comfort, 2. knee and hip angle and 3. Bar reach'n height. In my case I am only looking for 2hr bum comfort.... but hip/knee discomfort was almost instant on this bike for me.... so my priority was 2 then 3 and lastly 1.
Awesome job! Did you have to make any adjustment to the handlebars?HI team. I had to get back and up. It works for me 193cm
Cheers all
I bought the 25 and 50mm risers.... they come with bracket(s) to relocate the brake and clutch line joiner screwed under the triple clamp to allow for this..... once I settled on the 25's.... and was ok with the look... I bought a new 30mm longer clutch and brake line so I could remove the brackets and refit the line joiner blocks back under the triple clamp for a stock look. No wiring issues.I’m looking at bringing the handlebars on my Classic back 1-2 inches. Did you have any issues with your brake and clutch lines, or wiring?
Was the Tall comfort seat a BMW option? Also- which backrest did you buy for the bagger.6'6" here. R18B. Tall comfort seat was the only change I made. If I know its going to be a long highway day I'll pop the backrest on. Feels like a comfy recline with my feet up on the highway rests. I've done several 350+ miles days with this setup.
Go Apes! LolWell i,m like everyone else here , i,m 6 foot tall own a Classic , after about six months i fitted 1 inch bars risers, also i fitted a Corbin Gunfighter seat and backrest , this made a lot of difference as i sit "in" the bike rather than on it , to be honest though i should of fitted higher bar risers as i,m just short of having my arms fully extended but the back rest is great .
Can you share where you sourced this setup? Recently purchased 2023 R18 Classic. I don't see it ever becoming my go to long distance ride (GSA),but look forward to getting it comfortable enough for day rides. Thank you.6’2”. Works for me.
Replace the stock seat. It’s great looking, but definitely could have been used as a medieval torture device. When you are tall, it suffers from two issues:Can you share where you sourced this setup? Recently purchased 2023 R18 Classic. I don't see it ever becoming my go to long distance ride (GSA),but look forward to getting it comfortable enough for day rides. Thank you.
Reply
