Koso Speedo feedback
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1791081245#check"></use></svg></i> Discussion starter Discussion starter IN2R18s
Was toying with the idea to get one as installing is easy and is plug n’ play. My main interest was to test if it showed engine oil temp like the N9T does
I had one on my Goldwing - great little unit with a wealth of inputs. I don't think it would be plug & play so you would have to make up some kind of loom adaptor.
It took ebay global shipping over a month to get the gauge to me, but I now have it and I installed it today. The easiest install I have done. It took all of 3 minutes.
Unfortunately It doesn't look like it is possible to correct through the gauge. I did read somewhere that recent updates to GS-911 might allow speed correction......Still looking into that.
That would mean that in the future it might be possible to recalibrate the OEM Speedo as well ... Now that would be interesting 🤔
Really like this, thanks for sharing too. The gauge has a rev range up to 10,000 with the R18 bike maxing out at 5700……was there any gauge in the product range that maxed out at 8000 rpm at all ?
As far as I know, this is the only plugnplay speedo from Koso. So the rev range can't be changed. The shift light also can only be set as low as 4000 rpm, and then going up in 500 rpm increments. Mine is set at 4000 rpm.
