Kellermann Chrome ATTO DF rear lights
For sale new, never used, Kellermann Chrome ATTO DF lights for rear marker, brake and turn. they are ver small as you can see in the picture. Asking $175 plus shipping.
A sensational all-rounder​
A 3in1 sensation as it hasn’t been seen before: The Atto® DF is the latest and by far most spectacular member of Kellermann’s successful Atto® series! The probably world’s smallest street legal indicator is now available in triple function with an integrated rear and brake light. Behind the extremely small yet sensationally bright Atto® DF lays a multifunctional all-rounder: At the rear it is visually almost completely disguised with a light surface, which would fit four times on a 1 Cent coin! In result the rear of the motorcycle can be designed as clean and individual as never before. However, in action the Atto® DF shines with an intensity which has made Kellermann products legendary – it’s not the size but the illumination power that counts. Indicators, rear and brake light warn with an uncompromising intensity, clearly signalling the following traffic to keep its distance. Kellermann’s well-known HighPower LED technology** and EXtranz® - Extreme Optical Transparency Technology manage an optimized light channelling through a smart system of lenses and reflectors and thus enabling this combination of sensational brilliance and minimal size. The Atto® DF can be combined with various other series e.g. Atto® or Bullet 1000®. As the complete electronics are in the casing the Atto® DF allows for a significant reduction in weight.
* Possibly electronic equipment is needed to regulate the flashing rate.
** Combination out of the IC operated Longlife Protection Guard® system with high-performance-LEDs latest type of construction.
ECE-tested for rear​
  • replaces the existing rear / brake light as well as indicators
  • sensational new rear look
  • EXtranz® - Extreme Optical Transparency Technology
  • Kellermann HighPower LED Technology
  • Longlife Protection Guard®, IC operated, 330 kHz
  • High quality metal housing
  • Suitable for 12 volt DC applications
  • With M5x0,5x6,5 fastening screw
