burangs
I believe the 282 blinkers require dealer programming, no?
That would not, but I’m not holding my breath with the minis.Nope... I replaced my B model Blinkers with Blinkers designed to fit on the TC without any issues or error codes.
Probably a tricky way, to get folks to have the work completed at the dealership; the parts will cost under $300, the installation cost will most likely be North of that number, since the installation requires the entire front fairing to be disassembled.That would not, but I’m not holding my breath with the minis.
Do you have the part number or other info. I cannot locate them, but sure sounds like a strong possibility to fix the winglet issue
Please let me know how they workout for you. Thanks againhttps://www.shopbmwmotorcycles.com/...set-mini-led-blinkers-front-black-77515a1a282
I have some on order. My dealer said they’re sold singularly but I’m not so sure. Some places they’re described as a set as in the link above and some I’ve seen them described as a left or right indicator. Guess I won’t know for sure until they arrive but getting reimbursed for one of them would be great as they’re not cheapThey will 100% fix the rubbing issue though.
Will do, I am unsure about the need for coding. Install manual doesn’t mention it but it does on the accessory page which is odd.Please let me know how they workout for you. Thanks again
