Is that space normal?
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1791081245#check"></use></svg></i> Discussion starter Discussion starter Tim's R18FE
Tim's R18FE
Pennsylvania
2021 BMW R18 FE
Sorry for the bad picture, but that is a gap where the forks attract to the steerer. It’s the same on both sides but why would there be a spare there??
It is to allow the forks to be clamped correctly. If no gap the forks may not be held at the correct pressure. Have a look at the handlebar clamps it is the same on those with a gap at the rear only.
There are many example of clamping mechanisms on the bike.
-How your brake / clutch master cylinders clamps on to the handle bar.
-How at forks bottoms clamps on to the wheel axles.
100% need a torque wrench if you are doing any kind of maintenance on a motorcycle.
💯 on using a torque wrench
I downloaded many if not all of the installation documentation for the various accessories for my Model B; the documentation is very detailed, which includes torque specifications and tightening pattern steps.
