Is it hard to put air in the R18 base model tires?
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1791081245#check"></use></svg></i> Discussion starter Discussion starter motoring
motoring
05 r1200rt
Thought I read it can be had to get to the tire valve to put in air. I asked my dealer if they sell an 'L' shaped adapters to resolve that issue. Anyone do something likewise or is it not really needed?
ty
ty
Not needed, I have no problem checking the air pressure
I’ve just fitted 90 degree chrome valve extensions. Makes it a lot easier and I have the classic so the rear was a real bind to get in there.
whilst doing this I put some Goop in the tubes which is supposed to seal punctures as having inner tubes it’s a show stopper and recovery if you catch a puncture :cry:
Link to extensions please and thank you
Dealer suggested I wait until I need to change the tires on the R18FE, have yet to get it delivered. Seems they need to be removed from the bike maybe to change them out. I will put such low miles on the bike that will take many a year.
A friend said just restore my 1965 r60/2 instead. And as luck would have it, a good air head tech lives in GA so will tow my broken /2 up to his shop and just have him keep It until it is restored and running again. I have neither the tools nor knowledge or work shop to attempt that at my ’now’ young age.
I have a spare r69 engine, maybe between all the parts he can put something together. It got a broken piston ring so the jug would need to be enlarged which I infer the other jug would have to be as well.
Lord knows what type of little metal bits are buried inside all that oil I would almost have to think he will have to strip the engine down to the block and start from scratch which I’m sure is a lot of big bucks. At any rate, we now return you to your regular tv programming :)
Besides, at my age I figure the R18FE will be my last new bike purchase. Having it, plus any of my other bikes I keep, then getting the /2 running again would be a kick to have an old /2 and this new ‘reborn’ R5 reimagined R18FE bike.
My old /2 bike with earls fork front end will never look that sweet, though looking forward to see her running again while I am still on the top side of the truff soil:)
