I embedded a gel sheet in the sheet
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1791081245#check"></use></svg></i> Discussion starter Discussion starter yama
yama
BMW R18
ジェルシートのサイズは25cm×25cm×厚さ2cmです。
シート改良後、100kmほど走りました。走っているとシートのことを忘れてしまうほど快適でした
シートの改造は成功したと思います。私の体重は62kgです。
R18シートは固いと思っている方の参考になれば嬉しいです。
I was worried that the previous sentence was not in English, so I posted it again.
The size of the gel sheet is 25cm x 25cm x 2cm thick. I ran about 100km after seat improvement. It was so comfortable that I forgot about the seat when I was running. I think seat modification was a success. My weight is 62 kg.
I would be happy if it could be a reference for those who think that the R18 seat is solid.
