FYI - Compatibe battery maintenance chargers
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1789222567#check"></use></svg></i> Discussion starter Discussion starter Geo Z Man
Geo Z Man
Brisbane
R18 Transcontinental
If you want to plug a battery maintenance charger into one of the BMW fitted Power Outlets on a R 18 you must use a charger that supports the BMW CAN-bus electrical system. The Dealer originally sold me a Optimate 2 Pro Duo - great little charge but would not maintain the charge on my TC. I swapped it for a Optimate 4 Quad Program charger with CAN-bus feature and all works well now!
This has already been covered on the forum in detail Geo, if you do a search on the forum you’ll find all the threads. Optimate 4 CAN-bus is a popular choice 👍
I bought the Optimate 4 as well and it works perfectly all winter long. In spring it starts up in a flash.
