widu13
Not quite as dramatic as it sounds. Previously I have had difficulty starting my TC and the PHONE battery symbol was red. The alarm siren has always been muted, as in barely noticeable. That was about 6 weeks ago. Fri I had exactly the same issue for about a minute but this time there was no power at all, then lo and behold the ignition came live again with the low phone battery and it started but it lost the bluetooth connection to my phone and I had to re-pair it. I changed the fob battery just in case that was somehow affecting it.
I keep the bike on a tender and today took it for an 80 mile ride and came back and put it on the tender. I took it out to clean it about 5 hrs later and the alarm set off as I cleaned it with the keys on the seat. I tried the fob- nothing, so tried the power on- nothing. The fob would not even power anything it was totally dead. I tried this for a couple of minutes and then checked the voltage - 12.89v (it had only been off of the tender for about 15 mins) then I checked the main ground...all good, pulled the main fuse...all good but covered in road gunk with a fairly insignificant amount of corrosion on it. I wiped it off and replaced it. The bike would then power up and started, but was reporting an overdue service (was serviced by BMW last October).
I suspect that this is a perfect storm of low batteries in the DWA and a small bit of corrosion. No fault codes reported in MOTOSCAN, so I reset the service countdown. I will attempt to change the batteries in the DWA and will report any more issues. I just thought I would put my experience out there.
