DNA Filter Question
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1791081245#check"></use></svg></i> Discussion starter Discussion starter jtalka
jtalka
Jensen Beach, Florida
2022 R18 Transcontinental
Greetings from sunny and hot Florida;
I have a question on the DNA filter application. Today my TC is basically stock with Brentune stage 1, and stock air filter. I want to install the DNA filter. Question is, do I need to buy just their S2 Combo Kit or do I also need to buy their Stage 1 filter as well. (R-BM18CR20-1)? Also, is the swap out a fairly easy process unlike say a K1200LT where the tank needed to be removed?
Thanks,
Joel
Thanks all, going to pull the trigger on this one!
When you're removing the air filter screws that hold the stock air box cover in place, pay attention to them coming out. There's threaded inserts in the bottom of the airbox that the screws are threaded into. They have a tendency to come out instead of the screws themselves.
