Can anyone help me out with the dimensions of these 2 spacers for DK bars if you have them?
Unfortunately they were missing when I received the kit, hoping to source them locally if they're a generic part. I assume they would go by fastener size (ie M12), outer diameter, and length
Wow,U da Man TV!Alright. Got your measurements Sqeeps.
Big Spacer
length 54 (end to end)
diameter 32mm
M12
BUT there's a little wrinkle. The cylinder has a 2mm cuff at the end which has a diameter of 24mm.
Smaller Spacer
length 45mm
diameter 20mm
M10
it's black by the way
Hope this helps!
I would think the offset on the end is important since it is a additional spacer connected to the frame & engine.Good Job ,Bro!Alright. Got your measurements Sqeeps.
Big Spacer
diameter 32mm
M12
Smaller Spacer
length 45mm
diameter 20mm
M10
Hope this helps!
Ya shurWow,U da Man TV!
I see you will go great lengths to help a fellow R18 owner.
Appreciate you & thank you!
Regards,Tom
Hey I know I guy with a latheNow all you need is a lahe and some aluminum bar stock.
Or you cn try Mcmaster Carr
McMaster-Carr
McMaster-Carr is the complete source for your plant with over 595,000 products. 98% of products ordered ship from stock and deliver same or next day.www.mcmaster.com
