Cost of the 6K Service
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1789222567#check"></use></svg></i> Discussion starter Discussion starter Calboy
It will likely be a bit more than the 600 mile service. It's an oil change (no final drive though), valve clearance check and replace air filter. You save a bit on the lack of final drive fluid change, but the air filter & valve check will likely offset with slightly more time. Advantage of a boxer is valve checks are relatively easy compared to any other engine config since the cylinders are already out there.
