Copper vs Aluminum crush washers
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1791081245#check"></use></svg></i> Discussion starter Discussion starter BER18 100
BER18 100
Kansas
R18 Anniversary Edition
When fastening the brake and clutch lines, is it okay to use aluminum crush washers or are they too soft? I see aluminum used for drain plugs but copper is used for the hydraulic lines. Reason I'm asking....fresh out of copper crush washers.
Copper is a malleable metal vs Aluminum which often leads to cracks and fractures due to its rigidity characteristics..
Perhaps consider reusing the existing Copper washer in a pinch..?
I typically order 4 to 5 extra washers when purchasing supplies for DIY maintenance task..
In a bind - soften and reuse.
Routine maintenance - replace.
