Changing tire on 2022 R18TC
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1789222567#check"></use></svg></i> Discussion starter Discussion starter DonDMT
DonDMT
2022 BMW R 18 TC, 2022 BMW R1250 GSA
HOW ???
The TC sits so low, I can't figure how much I would have to jack it up to get the tire out.
I should say, mine has a sidecar attached so the bike is always in the upright position.
Hi There. I have a bagger. I bought the Hornig stand/lift and then a Vevor motorcycle lift to lift the lift :). Works great. Kind of a pain to have to do both, but then you can change tires, break pads, etc. without having to pay dealer prices since no one else will have the special stand you need to lift our bike.
HOW ???
Which brand of Sidecar did you eventually purchase ? Also, how does it ride / steer with the Sidecar ? Thanks, B.
Went with the DMC Patriot from Texas Sidecars. They really build a quality product.R18TC-SC.jpg
From what l have read, T. sidecars 100% improvement on the original company that produced them. When it comes to the TC, fairly stable handling with the chair ( heavier chair suited to bike ) ?
