BT Moto ECU Flash Group Buy and Discount!
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1791081245#check"></use></svg></i> Discussion starter Discussion starter BT Moto
Sign me up. It sounds like it is worth it. When is the close date on this? I'm not in a hurry if we want to try to get 20 or give other people a chance to sign up. Mostly riding the GS until there is a good rain to wash all the salt residue off the roads.
Ok, looks like we have 10. Did you guys want to wait to see if more are in? Or close it now and get you your handhelds? I'll leave the decision to you guys.
REMEMBER, We need all 10 to pay so if anyone wants to back out, now is the time. Conversely, if you want to throw in with the deal, we can add spots.
No close date, leaving it up to the group to decide on that.
Like I posted earlier...if we get to the $150 discount, I am in on this buy. The only reason, I don't jump on now, is that the $$ are tight right now (I wish I could). But, I will make it happen for the $150 deal.
AS REQUESTED, THIS IS THE GROUP BUY POST
IF YOU'D LIKE TO SIGN UP, JUST REPLY TO THIS THREAD AND YOU'LL BE ADDED TO THE LIST
We will leave this active until February 14th (or until people stop signing up for a few days in a row)​
COST:
Two tiers of cost
1. We get up to 10 people to purchase and we will give a $100 discount off our advertised $795 pricing
2. We get 20 or more people get a $150 discount off advertised pricing
WHO'S SIGNED UP SO FAR:
1. enzo5000
2. Adrian R
3. HanseDavion
4. Vyk
5. IDRider
6. azachko
7. burangs
8. estoma
9. Cheshire Cat
10. PistolPeteSTL
Why Flash Your R18's ECU? (Info)
STAGE 1 BENEFITS​
Perfect fueling, all the time! The BMW R18 comes equipped with wideband oxygen sensors stock which fully target fuel at every throttle position. Once setup, the bike is running an “auto” tuner all the time! Never needing custom adjustments for aftermarket parts, etc. The bike will adjust itself for the new parts! With the options below we have a full on unleashed and aural riding experience to enjoy this motorcycle to it’s best possible potential.
Here’s a list of everything we did with Stage 1:
  • Full-Time Closed Loop (FTCL) Fueling Adjustments
  • Removed RPM “Soft” Limiter
  • Rough Idle Fix – Cold and Warm
  • Increased Torque Limits
  • Increased Throttle Limiter To 100%
  • Sharper Throttle Response
  • More Aggressive “Rock” Mode Rumble
  • Increased Ignition Timing
  • Fixed Bucking and Rev Hang
  • Removed Top Speed Limiter
HOW WE ACCOMPLISH THIS WITH STAGE 1​
RESTRICTIONS REMOVED. The OEM throttle model has “soft” and “hard” limits. The soft limits are where the R18 will start to close the throttle and limit torque by itself near the RPM limiter. We removed the soft limiter that comes in 600RPM before the factory RPM limiter.
MODIFIED FUELING FOR FULL-TIME CLOSED LOOP AND WILL TARGET FOR BEST FUELING AND PERFORMANCE. Full-time closed loop tuning means your R18 can be programmed to always target a perfect AFR (air/fuel ratio). This new technology was just introduced by BMW and we utilize it to work at all times for you with Stage 1. Want to change parts on your bike and worried it may change your fueling? Worry no more with Stage 1.
MODIFIED IGNITION FOR ENHANCED PERFORMANCE. Stage 1 optimizes the ignition tables for performance and reliability. The R18 has multiple ignition tables. Depending on fuel quality, the bike will either choose more aggressive or less aggressive ignition map.
IDLE AND STARTUP FIXES. Complaints of idle and startup issues are common. Stage 1 fixes these issues and ensures your bike starts up and idles right the first time, every time.
INCREASED TORQUE LIMITS. Torque limits removed to give you more torque in the midrange and low end (see dyno graphs below).
THROTTLE INCREASED TO 100%. Factory throttle limits are common these days. Our Stage 1 flash removes all throttle limiters and gives you the power your bike should have had right from the factory. The factory R18 throttle limiters are at 3500RPM.
SHARPER THROTTLE RESPONSE. Throttle response sharpened to give you a more lively and responsive feel on the road.
INCREASED “ROCK” MODE RUMBLE. Ready to Rock? “Rock” mode idle gives you slightly more rumble and shake, while “Roll” mode still retains its functions with no shake.
INCREASED IGNITION TIMING. Ignition timing carefully increased to yield optimized power while still giving you OEM reliability and rideability.
FIXED BUCKING AND REV HANG. Low RPM bucking and throttle lift “rev hang” have been reduced with Stage 1.
REMOVED TOP SPEED LIMITER. Top speed limiter of 110MPH had been removed with Stage 1
DYNO
The R18 isn’t know to be a powerhouse but there’s still power to be made. With our Stage 1 flash we were able to gain 6WHP and 4WTQ. We also were able to smooth the throttle with sharper response. All dyno runs performed back to back on our in-house DynoJet with the only difference being our Stage 1 flash.
BLUE = Stage 1 with 93 Pump Gas, 83WHP / 114WTQ
RED = Factory tuning with 93 Pump Gas, 77WHP / 110WTQ
The graph below shows partial throttle power. We gave the R18 more partial throttle power through the entire RPM range and were able to make the bike smoother and more predicable.
RIDE IMPRESSIONS
Sign LLOYDW1 up also.
I’m doubting we’ll get 20 participants. I vote we shut this group buy down Friday unless we get more buyers in the next 2 days. Thoughts?
