BMW R18 Homage saddle
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1791081245#check"></use></svg></i> Discussion starter Discussion starter Gilles
Not knowing when the R18 Homage seat will be available, I decided to buy a R25 seat and try to adapt it.
Initially, I wanted to install it complete with the spring suspension, but the resulting seat position was too high and not aesthetic.
Finally, the spring support legs have been cut off, and the seat was installed fixed with temporary supports.
selle-r25-montage-test-7-jpg.2358
selle-r25-montage-test-3a-jpg.2359
selle-r25-montage-test-14a-2-jpg.2360
The seat position is a little higher than the original one, and slightly forward.
It is also shorter in length, and surprisingly rather confortable (but I don't find the original seat uncomfortable compared to my previous bike !!
I like to be closer to the handlebars, I'am 1.75m and my arms are not stretched which is relaxing.
I have also to get used to the position of the feet on the brake pedal, also slightly forward.
More riding tests are necessary before confirming the right position and finalizing the seat supports
From the pictures, it appears to push you 6 inches closer the bars?
Can not be a comfortable riding position.
"Just sayin"
Regards,Tom
Saying What?
Did you notice that this picture is of a Hardtail and would be brutal to ride around the block, regardless of seat position.
Comfortable seat position is almost irrelevant on a Hardtail.
Giles bravo! This is exactly the look that drew me to buy the r18. It’s been a few weeks now. How are you getting on with the r25 seat? I have pretty much the same seat on my r51/3 and if it can be adapted to the r18, I’m in! :)
Thanks !
The final supports were made and are in painting now. I will post the photos soon
Here they are, painting is not perfect but it will do the job
Heh Giles. My bike arrives Wednesday and I’m tempted to order the R25 seat in advance :) Did you have these supports fabricated or did they come with the seat?
No, you have to fabricate them and to remove the damper support of the R25 seat
Gilles you have done brilliantly!
Forgive me but i have no experience with commissioning fabrication. Did you supply technical diagrams or simply explain what you needed?
How would you recommend making the same midification? Just buy the saddle and find a friendly fabricator? :)
Congrats on a great mod :)
John
Thanks John
At first I tinkered with a temporary assembly with steel angles in order to validate the position of the saddle and the modifications to be made to it.
Then I drew templates to have them manufactured by a specialist.
For responsibility reasons, I don't want to make them public!
Thanks John
Contact me in PM to have photos; for responsibility reasons, I don't want to make them public!
Yo Gilles, I sent you a PM regarding your seat solution, so please check when you have time :)
