Bike Week weekend in Florida.
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1791081245#check"></use></svg></i> Discussion starter Discussion starter emgarciax
what's the usual attendance at Daytona bike week? I need to make it down there some year. Also, where is the camera mounted? On a selfie stick??
Insta360 X4 Air and not too long of a stick.
Trying to keep it reachable (start/stop recording) and stable / reliable.
This is why I also used a silicone band support as a safety measure.
Last few years been 200K to 350K depending on which data you look at. In the 90s we it hit 1/2 million in attendance several years.
Which mounting hardware are you using? I just purchased the X4 Air with the Motorcycle Bundle but the clamp doesn't securely fit the mirror arm. I added it to Bag crash bar
I mixed and matched mounts until I found what works for me prioritizing security, safety and looks.
This setup is safely secured, within easy reach of my left hand to star / stop recoding and blends in the looks.
I use the Rear View Mirror Mount base.
https://store.insta360.com/product/rear-view-mirror-mount?c=2871&from=search-results
with the stick that comes with the Third-Person Bike Handlebar Mount
https://store.insta360.com/product/thirdperson_bike_handlebar_mount?c=1958&from=search-results
and the X5/X4 Air Quick Release which allows me to leave this setup on the bike and quickly release the camera off.
https://store.insta360.com/product/x5-quick-release-mount?c=3926&from=search-results
additional support (just in case) with silicone cable ties
https://www.amazon.com/dp/B0D4YWDLPR?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_3&th=1
This last is just precautionary.
The trick is to set the ball joint base in a maxed out angle so that no further movement down or back is allowed.
Tested over long and fast distances.
To further improve safety of operation of the Insta360 X4 Air, I just got the Ring Remote.
Now I don't even have to take my hand of the handlebars.
The additional benefit is that I will be less hesitant on start / stop recording which should make editing easier. Shorter clips make editing easier.
