Zero-FG
Thanks for th
Thanks for the quick response, when you wired the switch, was there a plug end connection to the switch block at all ?I did not replace the switch, the stock one works you just dont have the icon on it. The wiring harness listed in this post may have been the wrong one for my application but all connections were good with the exception of the end that connects to the left and right blinker cables are male instead of female, so I had to cut the ends off the original blinkers to splice at the ends of the wiring harness. Other than that, it was an easy process once I found the harnesses under the windshield fairings.
