The ASC warning light indicator on the panel shows up every time the ignition switch is turned on. Does that mean ASC has to be manually reset with the button on the clutch side of the handlebar...every time ignition switch is turned on in order to activate ASC? Reading the manual is confusing to me. Once the ASC button is pressed for a couple of seconds, the ASC warning light goes off...does that mean the ASC is active or inactive? Thanks folks.....I think I have a brain fart.......
