Adding a phone charging cable to 2021 R18 first edition?
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1791081245#check"></use></svg></i> Discussion starter Discussion starter JeffwithaG
JeffwithaG
Cleveland, Ohio
BMW R18 First Edition
I have a 2021 R18 First Edition and would like to add a phone charging cable to plug into my QuadLock. Has anyone done this before? I assume it's just running a fused wire to the battery?
Thanks
I purchased a USB port charging cable from Hornig , there are others of course Nippy Normans sell them as well , attached mine to the battery then cabled on too my frame . Easy Job .
Thanks
yeap,you'll need to remove the battery. i have a quad lock wireless charging set up on my bike...
I bought he QuadLock cable and charging head. Getting the battery out is really difficult, but taking the tank off is worse. How do you disconnect the electrical connector on the left side?
