Thank you.Yes, they fit the bagger. I did not file the winglets or extend the position of the turn signals on my bagger so the turn signals would not touch the winglets. There are several threads on this forum which discuss this issue. In the position where the winglets deflect the most wind, they will slightly touch the turn signals.
I added winglets to my B. Cut em to clear the signals with dremel. Took a brisk ride Friday and seemed that there was less cold air hitting me.Thank you.
Jim,I added winglets to my B. Cut em to clear the signals with dremel. Took a brisk ride Friday and seemed that there was less cold air hitting me.
My first go at a dremel, so completely unskilled. Just used the dremel cutting wheel and then tried to sand/polish the cut edge a bit to clean it up. Doesn’t look horrible, but could have done a better job with it.Jim,
Cut down or sanded/ground down? Relatively easy?
