Top case
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1791081245#check"></use></svg></i> Discussion starter Discussion starter Tobrouk47
Tobrouk47
Villeneuve sur Lot
R18 First édition
Peut-on installer un top case sur R18 First édition vu que le porte bagage installé est courbé? Si oui, quelle marque avec 55 L minimum serait compatible?
Merci pour vos réponses.
Merci pour cette réponse, 1749794625603.jpeg c’est installé par BMW est vu qu’il est courbé, je crains que cela soit difficile !Encore merci pour votre attention.
Thank you for this reply, View attachment 18204 it is installed by BMW and since it is curved, I fear that it will be difficult! Thank you again for your attention.
Yup it's going to be a bit difficult, my recommendation would be to find a universal mounting plate for a top box and then use some u bolt connectors at the front and back of the rack to bolt it down.
Here's a plate from the one I use from Amazon. I ended up mounting this to a top case rack from Amazon that bolts up to the same spot yours is but is flat so it was easy to mount.
Hope this helps
https :// a . co / d / cqNNirw
https :// a . co / d / 8VcDTIr
