The R18B is almost perfect.......but not totally
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1791081245#check"></use></svg></i> Discussion starter Discussion starter Deleted member 1344
I've read and watched a ton of stuff online about the R18 B prior to me purchasing one... I've concluded that mostly, if not everything online is total BS, the vibration thing - BS, the cylinders interfering with your feet - BS..!!! and the foot brake pedal being awkward - that one was true for me... 😆
In short, swapping my brake pedal out for the RSD pedal has actually increased my use of the rear brake, vs the distributed brakes via the hand lever.
I went for a six hour ride with HD buddies, my R18 B is absolutely smooth... In the end, it doesn't matter what you ride - as long as you're riding...
Concur, on each point.
