Scott Semone
The attached PDF shows the different steps that I took to install the Auxiliary Lights & Winglets, typically found on the R 18 Transcontinental onto the Model-B Bagger. The total cost of the project is between $1,200 to $1,300 depending on whether or not you need to purchased additional tools.
I used the existing Accessory Outlet in order to power the Auxiliary Lights vs using the pre-wired Auxiliary Light wiring harness located underneath the front left side (clutch side) fairing; however I did cut and harvest the plug in order to complete the circuit from the existing Accessory 12V wiring (Remember: Brown = Negative Ground). The Accessory Outlet is switched ON via the ignition / Power Button, and remains powered in the ON state for approximately 3 min. after turning OFF the bike. I installed a 16mm diameter latched LED push-button switch within the existing 12V power outlet; this avoids having to cut or alter the OEM dash-instrument panel.
Any questions - Please don't hesitate to reach out. Scott
