Dpolo1
Ok I just changed the oil and filter on my 18. Replaced with 4 quarts of oil . Rode the bike 10 miles checked site glass on level ground holding the bike straight up. Shows no oil.
Very good pointOne other thing:
Fresh oil, if filled to the very top of the sight glass, will make it look like there's no oil, as the oil is semi-clear (light amber color).
Double-check that you didn't overfill by putting your bike on its sidestand, then slowly and carefully, tip it upwards while observing the sight glass.
One other thing:
Yep. About .25 liters short if you’re filled up with 4 quarts.My mistake , a liter is .06 more than a guart 0.6 x 4 = so I'm short . Added a little more oil . Duh !
As long as your low pressure warning light doesn't come on you are still OK ... but filling it to the mark is always bestMy mistake , a liter is .06 more than a guart 0.6 x 4 = so I'm short . Added a little more oil . Duh !
