R18 suspension upgrade
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1791081245#check"></use></svg></i> Discussion starter Discussion starter tbonesixtynine
I just can't believe the wilburs or ohlins can help, it only 3 and a half inch travel.
It adds inch of travel, or overall length which only raises the rear end. Changing geometry. No help at all you can't do much with only 3 1/2 inch. Harley has the same . So no change ,this is a joke. Sounds like wilburs employees or someone getting paid to promote these shocks.
Not going to make much difference. I'll save my money not worth it.
Just fitted the +20mm Wilbers. Dramatic improvement. Smooth. Highly recommend.
Well that's not much info. How many miles have you ridden it with new suspension.
