R18 brake lines and clutch lines
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1749751632#check"></use></svg></i> Discussion starter Discussion starter BER18 100
BER18 100
Kansas
R18 Anniversary Edition
When determining if brake and clutch lines are 8mm, 10mm, or 12mm,
are they referring to the diameter of the banjos?
For the R18, is the correct answer 10mm?
