R18 B with winglets
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1791081245#check"></use></svg></i> Discussion starter Discussion starter lonnmcqq
The Mini-directionals will absolutely fit on the Model B and not interfere with the OEM Winglets; there's a picture somewhere on the forum; however, I can't find it - but did find the below comparison picture:
The winglets do not contact the mini LED lights when the winglets are closed. But the LED lights are in the way of opening the winglets.
thank you for posting your picture with the mini LED lights and the winglet. I have been searching this forum for a picture and was not able to find one. I’m thinking of adding the winglets to my R18B, and replacing the stock blinker with the mini LED blinker to do so. Can you advise whether the mini LED lights contacts with the winglets when you open/close the winglet?
