NOCO NLP30
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1758297946#check"></use></svg></i> Discussion starter Discussion starter laennecr
laennecr
'22 R18 Classic
Did a search and found old posts so here is a new one. Battery died hard today, leaving me to push the Classic - with sidecar - 10 blocks home 😳. Figured it was faster than a tow or getting a trailer. Literally a pain in the ass 😭.
Replaced the OEM, 4 year old AMG battery, with a LiFePO4 NOCO NLP30 ( https://no.co/nlp30 ). Fit perfectly and so far so good. I’ve been using a NOCO NLP20 in my R9t for two years now with zero issues. Anyone else? BTW…. the substantially lighter weight made the actual installation MUCH easier.
Wat to go @laennecr 👍
LiFePo4 is a lót better battery technology.
Yes the weight difference is surreal; like picking up an empty milk carton which you thought full.
Do you have threads on your sidecar?? Found only one post with a photo of your dog in the Ural chair. Please share some more.
Over here it is stupidly difficult and thus expensive to the point of prohibitive, as in 12k€, to fit one to the R18 otherwise it would be on mine already.
As requested.
