Need help
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1791081245#check"></use></svg></i> Discussion starter Discussion starter SoCalR18B
SoCalR18B
Anaheim Hills, CA
2023 BMW R18 Bagger
Hi all!
I’ve tried searching for this, but without any luck - so hoping someone can either point me in the right direction or give me a quick tutorial.
I need to replace the front turn signals on the Bagger. I don’t feel comfortable just splicing the wires together.
How far up are the connectors for the signals?
Do I need to take apart the whole fairing to get to them?
Thank you in advance!
Hi all!
Like Scott says you will need to take the fairing apart and the connections for the blinkers are on each side of the headlight about midway. Left on left side and right on right side.
Did you replace with Oem signals or after market? I’m replacing mine with after market and am wondering how you went about it if you went after market. I was trying to replace with Roctane signals using my reverse rebate but that was a no go. I’m installing Kuryakyn Bullet 1000s. They have three wires and not sure how to wire it up to the two/plug for the bike.
