MikeB
2k miles after BT Moto ECU Flash and DNA filter installed, I noticed my mpg has dropped from 47 mpg to 38 mpg. Is this normal? What’s your mpg after the upgrade?
Averaging about 42mpg ...It goes down with greater revs. I am assuming you went with stage 2 DNA?2k miles after BT Moto ECU Flash and DNA filter installed, I noticed my mpg has dropped from 47 mpg to 38 mpg. Is this normal? What’s your mpg after the upgrade?
Is a DNA air filter, I have stage 2 combo https://www.motodracing.com/dna-bmw-r-18-air-filter-stage-2-combo-2020-bm18cr20-s2-comboDumb question ... what's a 'DNA' filter?
Thank you for your compliment but my wife think my driving is boring ... here's a short clipA 20% decrease in gas mileage sounds more like a different riding style than fuel/air mixture. Is it possible you're riding a bit more aggressive with the new tune?
Ahhhh now I remember .. there was more talk about that in other threads ... I forgot ... sigh .Is a DNA air filter, I have stage 2 combo https://www.motodracing.com/dna-bmw-r-18-air-filter-stage-2-combo-2020-bm18cr20-s2-combo
Yes .... but where is the fun in thatRain mode if you want better fuel mileage.
My frustration is that for a 4 gallon tank I'm having to stop more often than I expected to fill up. The people I ride with mostly go 150 - 160 miles between fill ups and my gas light comes on way before that. It's like I'm the chump rolling on a Sportster that has to get gas every 100 miles. Not that getting 45 mpg instead of 39 would fix that entirely, but it seems to be that gas mileage doesn't meet the expectations for some riders.None; but he wants fuel economy. My 2 cents worth. I wouldn’t know what my fuel economy is . When the tank is low, fill it up and ride. l have the DNA filter. Breathes better. That is all that matters.
Thanks for the info.Ahhhh now I remember .. there was more talk about that in other threads ... I forgot ... sigh .
I have a few thoughts to your MPG change ... you are adding more air to the mixture by having a high-flow air filter (I am assuming that this is the idea behind that filter) in that case the ECU will add more fuel to the mixture in order to come back to the proper mix-ratio ... but that theory has a bit of a hole ... because your riding style hasn't changed and you are pumping the same amount of fuel mixture through your engine ... but then I thought, you did just have the ECU flashed and it may have gone into 'learning mode' which can have also an impact on fuel mileage.
I did something really stupid (I am good at that) a couple months back and had to factory reset my ECU .. which meant full-on learning mode and my gas mileage was horrible for the first 2 gas tanks .. then it started dialing back in.
IMO ... just run through a few tanks of gas and then see if it dials back in ... if not, revisit the subject
EDIT: Thanks R18C!
The good news is for me it doesn't seem to get much worse mileage when I ride harder than when I ride like a grandpa. On my other bikes the difference between flogging it and taking it easy is much more noticeable. Heck, on my Triumph last summer when I was at Sturgis and riding chill I got over 60 mpg out of two tanks in a row on my Triumph. When I ride that bike around town where the roads aren't clogged with geezer glides I average 48. That's a difference.
Seems normal to me to discuss fuel consumtion after mods. I don't see anyone complaining.Seems odd to me for someone to do performance mods to their motor and then complain about a fuel mileage drop.
My bike is still in it's stock configuration, with the exception of my exhaust system (J-&-H); I consistently get much better fuel economy than my buddies who all ride HD.My frustration is that for a 4 gallon tank I'm having to stop more often than I expected to fill up. The people I ride with mostly go 150 - 160 miles between fill ups and my gas light comes on way before that. It's like I'm the chump rolling on a Sportster that has to get gas every 100 miles. Not that getting 45 mpg instead of 39 would fix that entirely, but it seems to be that gas mileage doesn't meet the expectations for some riders.
