Kern Stabi Bolts
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1789222567#check"></use></svg></i> Discussion starter Discussion starter alnytn
alnytn
TN
2021 R18
Does anybody know the thread size of the Stern Kerbi adaptors that screw into the front of the engine ?
Also, has anybody jacked the bike up using a scissor jack and a 2x4 across the pan in front and another across the exhaust hangers. I was told this is ok by a dealer.
Ace Hardware has a thread size calculator to determine size and pitch. Take the adapter bolt that came with the lift and duplicate it at Ace.
I bought the extra bolt from Hornig. Not smart as the alignment is wrong. Placed it up against my bench grinder thinking it would fit if I rounded off the stock dimensions. No deal.
