Does anyone have experience with ordering custom lines? There are quite a few bend and curve options for banjo bolts.
1) The R18 would use the 10mm size I would assume?
2) The stock banjo bolts are domed with Torx fitting, but hex head from Galfer should be okay, right?
3) My guess is the length is measured from where the circular fitting is crimped to the lines?
